71 Pantera well worn 377 twin turbo motor. After a short trip yesterday I noticed one of my turbos was leaking oil. A small amount on the input (pressure) side. A quick tightening and it was fine. I did notice a small paint bubble on the deck directly above the turbo. There is about 2 inches clearance about the turbos but the deck was really hot to the touch. Question. I am looking for a product that can be applied (as a sheet or thin blanket) to the underside of the deck above the turbo. I have some chromed sheet metal shields that I may be able to fit to the turbos but would like the real protection of an insulator. Thanks in advance to the "collective", jerry knotts
This is a list of stuff a lot or racers use to protect their bodywork. Some of it is pretty expensive, but so is paint... https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER Paul #9270 On 6/30/2016 8:57 AM, Jerry Knotts wrote:
jerry knotts
Thanks Paul. This looks like what I am looking for. On 6/30/2016 9:05 AM, Paul Timko wrote:
Paul #9270
jerry knotts
Neat website.
On 6/30/2016 9:05 AM, Paul Timko wrote: This is a list of stuff a lot or racers use to protect their bodywork. Some of it is pretty expensive, but so is paint...
Paul #9270
jerry knotts
Jerry, I've found the best way to keep turbo heat away from a painted surface that is so close as your 2" would be to use a preformed turbo hugging insulation cover that is ceramic cloth inner lined with a hard ceramic plate shield that is elevated above the turbos and close to parallel to your painted surface. Your hard plate will be the last real defense against the heat and will allow air to pass between the plate and your painted panels-very important! You can then apply aluminum faced extruded ceramic cloth or another ceramic plate to your inner body surface for its reflective values with epoxied to body screw supports or tinnerman clip studs that keep said plate off the bodies surface for another air flow or insulation boundary. Next would be ceramic coating all exhaust and turbos and using air ducts to flush area. Basically holding heat back while flushing the heated area with air will save your painted body. Keep cool, Jeff Jeff Cobb- I pad W-225-343-7525 C-225-907-4514 Jeff Cobb Auto Works 1316 S. Acadian Thruway Baton Rouge, La. 70806 www.LiveOakConcours.org On Jun 30, 2016, at 9:27 AM, Jerry Knotts <knottsj@galstar.com> wrote:
Paul #9270
jerry knotts
Jerry, I've found the best way to keep turbo heat away from a painted surface that is so close as your 2" would be to use a preformed turbo hugging insulation cover that is ceramic cloth inner lined with a hard ceramic plate shield that is elevated above the turbos and close to parallel to your painted surface. Your hard plate will be the last real defense against the heat and will allow air to pass between the plate and your painted panels-very important! You can then apply aluminum faced extruded ceramic cloth or another ceramic plate to your inner body surface for its reflective values with epoxied to body screw supports or tinnerman clip studs that keep said plate off the bodies surface for another air flow or insulation boundary. Next would be ceramic coating all exhaust and turbos and using air ducts to flush area. Basically holding heat back while flushing the heated area with air will save your painted body. Keep cool, Jeff Jeff Cobb- I pad W-225-343-7525 C-225-907-4514 Jeff Cobb Auto Works 1316 S. Acadian Thruway Baton Rouge, La. 70806 [1]www.LiveOakConcours.org On Jun 30, 2016, at 9:27 AM, Jerry Knotts <[2]knottsj@galstar.com> wrote: Thanks Paul. This looks like what I am looking for. On 6/30/2016 9:05 AM, Paul Timko wrote: This is a list of stuff a lot or racers use to protect their bodywork. Some of it is pretty expensive, but so is paint... [3]https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER Paul #9270 On 6/30/2016 8:57 AM, Jerry Knotts wrote: 71 Pantera well worn 377 twin turbo motor. After a short trip yesterday I noticed one of my turbos was leaking oil. A small amount on the input (pressure) side. A quick tightening and it was fine. I did notice a small paint bubble on the deck directly above the turbo. There is about 2 inches clearance about the turbos but the deck was really hot to the touch. Question. I am looking for a product that can be applied (as a sheet or thin blanket) to the underside of the deck above the turbo. I have some chromed sheet metal shields that I may be able to fit to the turbos but would like the real protection of an insulator. Thanks in advance to the "collective", jerry knotts _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [4]DeTomaso@server.detomasolist.com [5]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [6]DeTomaso@server.detomasolist.com [7]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [8]DeTomaso@server.detomasolist.com [9]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://www.LiveOakConcours.org/ 2. mailto:knottsj@galstar.com 3. https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER 4. mailto:DeTomaso@server.detomasolist.com 5. http://server.detomasolist.com/mailman/listinfo/detomaso 6. mailto:DeTomaso@server.detomasolist.com 7. http://server.detomasolist.com/mailman/listinfo/detomaso 8. mailto:DeTomaso@server.detomasolist.com 9. http://server.detomasolist.com/mailman/listinfo/detomaso
I second that the cloth and aluminium foils are top rate. Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Paul Timko <thedrol@pobox.com> Sent: Thursday, June 30, 2016 7:05 AM To: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Insulation material? This is a list of stuff a lot or racers use to protect their bodywork. Some of it is pretty expensive, but so is paint... https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER Paul #9270 On 6/30/2016 8:57 AM, Jerry Knotts wrote:
jerry knotts
_______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. I second that the cloth and aluminium foils are top rate. Julian __________________________________________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Paul Timko <thedrol@pobox.com> Sent: Thursday, June 30, 2016 7:05 AM To: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Insulation material? This is a list of stuff a lot or racers use to protect their bodywork. Some of it is pretty expensive, but so is paint... [1]https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER Paul #9270 On 6/30/2016 8:57 AM, Jerry Knotts wrote:
jerry knotts
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com [2]http://server.detomasolist.com/mailman/listinfo/detomaso
tightening directly list.
Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com [3]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER 2. http://server.detomasolist.com/mailman/listinfo/detomaso 3. http://server.detomasolist.com/mailman/listinfo/detomaso
I recall reading a blurb from NASA (ya I read that stuff too)that the gold color faced insulation was much better then the aluminum color faced insulation. You do see it in all the photos of the space craft. Let's see if Terry knows about this. Larry (what happened to the "Pure Gold" car?) - Cleveland -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Julian Kift Sent: Thursday, June 30, 2016 10:29 AM To: Paul Timko; detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Insulation material? I second that the cloth and aluminium foils are top rate. Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com> on behalf of Paul Timko <thedrol@pobox.com> Sent: Thursday, June 30, 2016 7:05 AM To: detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Insulation material? This is a list of stuff a lot or racers use to protect their bodywork. Some of it is pretty expensive, but so is paint... https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER Paul #9270 On 6/30/2016 8:57 AM, Jerry Knotts wrote:
jerry knotts
I will look into it. I have a piece of shielding in my office. It has 20 layers. But right now I am crushed building the departure sequences for Dawn. Plus we have Juno JOI this weekend. Crazy stuff happening all weekend. http://www.jpl.nasa.gov/ Get back to you later… "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> 🇺🇸 From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Larry - Ohio Time <Larry@ohiotimecorp.com<mailto:Larry@ohiotimecorp.com>> Date: Thursday, June 30, 2016 8:36 AM To: 'Julian Kift' <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>>, 'Paul Timko' <thedrol@pobox.com<mailto:thedrol@pobox.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Insulation material? I recall reading a blurb from NASA (ya I read that stuff too)that the gold color faced insulation was much better then the aluminum color faced insulation. You do see it in all the photos of the space craft. Let's see if Terry knows about this. Larry (what happened to the "Pure Gold" car?) - Cleveland -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Julian Kift Sent: Thursday, June 30, 2016 10:29 AM To: Paul Timko; detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Insulation material? I second that the cloth and aluminium foils are top rate. Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Paul Timko <thedrol@pobox.com<mailto:thedrol@pobox.com>> Sent: Thursday, June 30, 2016 7:05 AM To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Insulation material? This is a list of stuff a lot or racers use to protect their bodywork. Some of it is pretty expensive, but so is paint... https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER Paul #9270 On 6/30/2016 8:57 AM, Jerry Knotts wrote: 71 Pantera well worn 377 twin turbo motor. After a short trip yesterday I noticed one of my turbos was leaking oil. A small amount on the input (pressure) side. A quick tightening and it was fine. I did notice a small paint bubble on the deck directly above the turbo. There is about 2 inches clearance about the turbos but the deck was really hot to the touch. Question. I am looking for a product that can be applied (as a sheet or thin blanket) to the underside of the deck above the turbo. I have some chromed sheet metal shields that I may be able to fit to the turbos but would like the real protection of an insulator. Thanks in advance to the "collective", jerry knotts _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. I will look into it. I have a piece of shielding in my office. It has 20 layers. But right now I am crushed building the departure sequences for Dawn. Plus we have Juno JOI this weekend. Crazy stuff happening all weekend. [1]http://www.jpl.nasa.gov/ Get back to you later... "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [2]thimes@jpl.nasa.gov From: DeTomaso <[3]detomaso-bounces@server.detomasolist.com> on behalf of Larry - Ohio Time <[4]Larry@ohiotimecorp.com> Date: Thursday, June 30, 2016 8:36 AM To: 'Julian Kift' <[5]julian_kift@hotmail.com>, 'Paul Timko' <[6]thedrol@pobox.com>, "[7]detomaso@server.detomasolist.com" <[8]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Insulation material? I recall reading a blurb from NASA (ya I read that stuff too)that the gold color faced insulation was much better then the aluminum color faced insulation. You do see it in all the photos of the space craft. Let's see if Terry knows about this. Larry (what happened to the "Pure Gold" car?) - Cleveland -----Original Message----- From: DeTomaso [[9]mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Julian Kift Sent: Thursday, June 30, 2016 10:29 AM To: Paul Timko; [10]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Insulation material? I second that the cloth and aluminium foils are top rate. Julian ________________________________ From: DeTomaso <[11]detomaso-bounces@server.detomasolist.com> on behalf of Paul Timko <[12]thedrol@pobox.com> Sent: Thursday, June 30, 2016 7:05 AM To: [13]detomaso@server.detomasolist.com Subject: Re: [DeTomaso] Insulation material? This is a list of stuff a lot or racers use to protect their bodywork. Some of it is pretty expensive, but so is paint... [14]https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER Paul #9270 On 6/30/2016 8:57 AM, Jerry Knotts wrote: 71 Pantera well worn 377 twin turbo motor. After a short trip yesterday I noticed one of my turbos was leaking oil. A small amount on the input (pressure) side. A quick tightening and it was fine. I did notice a small paint bubble on the deck directly above the turbo. There is about 2 inches clearance about the turbos but the deck was really hot to the touch. Question. I am looking for a product that can be applied (as a sheet or thin blanket) to the underside of the deck above the turbo. I have some chromed sheet metal shields that I may be able to fit to the turbos but would like the real protection of an insulator. Thanks in advance to the "collective", jerry knotts _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [15]DeTomaso@server.detomasolist.com [16]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [17]DeTomaso@server.detomasolist.com [18]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [19]DeTomaso@server.detomasolist.com [20]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. http://www.jpl.nasa.gov/ 2. mailto:thimes@jpl.nasa.gov 3. mailto:detomaso-bounces@server.detomasolist.com 4. mailto:Larry@ohiotimecorp.com 5. mailto:julian_kift@hotmail.com 6. mailto:thedrol@pobox.com 7. mailto:detomaso@server.detomasolist.com 8. mailto:detomaso@server.detomasolist.com 9. mailto:detomaso-bounces@server.detomasolist.com 10. mailto:detomaso@server.detomasolist.com 11. mailto:detomaso-bounces@server.detomasolist.com 12. mailto:thedrol@pobox.com 13. mailto:detomaso@server.detomasolist.com 14. https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER 15. mailto:DeTomaso@server.detomasolist.com 16. http://server.detomasolist.com/mailman/listinfo/detomaso 17. mailto:DeTomaso@server.detomasolist.com 18. http://server.detomasolist.com/mailman/listinfo/detomaso 19. mailto:DeTomaso@server.detomasolist.com 20. http://server.detomasolist.com/mailman/listinfo/detomaso
PS - When you go to the JPL web page, pay attention to the Ceres bight spot. That is an image I did. We are trying to get one more IR Image pass over Occator before we depart for Adeona. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov> 🇺🇸 From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Terry Himes <Terry.Himes@jpl.nasa.gov<mailto:Terry.Himes@jpl.nasa.gov>> Date: Thursday, June 30, 2016 8:51 AM To: Larry - Ohio Time <Larry@ohiotimecorp.com<mailto:Larry@ohiotimecorp.com>>, 'Julian Kift' <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com>>, 'Paul Timko' <thedrol@pobox.com<mailto:thedrol@pobox.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Insulation material? I will look into it. I have a piece of shielding in my office. It has 20 layers. But right now I am crushed building the departure sequences for Dawn. Plus we have Juno JOI this weekend. Crazy stuff happening all weekend. http://www.jpl.nasa.gov/ Get back to you later… "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 thimes@jpl.nasa.gov<mailto:thimes@jpl.nasa.gov><mailto:thimes@jpl.nasa.gov> 🇺🇸 From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com><mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Larry - Ohio Time <Larry@ohiotimecorp.com<mailto:Larry@ohiotimecorp.com><mailto:Larry@ohiotimecorp.com>> Date: Thursday, June 30, 2016 8:36 AM To: 'Julian Kift' <julian_kift@hotmail.com<mailto:julian_kift@hotmail.com><mailto:julian_kift@hotmail.com>>, 'Paul Timko' <thedrol@pobox.com<mailto:thedrol@pobox.com><mailto:thedrol@pobox.com>>, "detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com>" <detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com>> Subject: Re: [DeTomaso] Insulation material? I recall reading a blurb from NASA (ya I read that stuff too)that the gold color faced insulation was much better then the aluminum color faced insulation. You do see it in all the photos of the space craft. Let's see if Terry knows about this. Larry (what happened to the "Pure Gold" car?) - Cleveland -----Original Message----- From: DeTomaso [mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Julian Kift Sent: Thursday, June 30, 2016 10:29 AM To: Paul Timko; detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Insulation material? I second that the cloth and aluminium foils are top rate. Julian ________________________________ From: DeTomaso <detomaso-bounces@server.detomasolist.com<mailto:detomaso-bounces@server.detomasolist.com><mailto:detomaso-bounces@server.detomasolist.com>> on behalf of Paul Timko <thedrol@pobox.com<mailto:thedrol@pobox.com><mailto:thedrol@pobox.com>> Sent: Thursday, June 30, 2016 7:05 AM To: detomaso@server.detomasolist.com<mailto:detomaso@server.detomasolist.com><mailto:detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Insulation material? This is a list of stuff a lot or racers use to protect their bodywork. Some of it is pretty expensive, but so is paint... https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER Paul #9270 On 6/30/2016 8:57 AM, Jerry Knotts wrote: 71 Pantera well worn 377 twin turbo motor. After a short trip yesterday I noticed one of my turbos was leaking oil. A small amount on the input (pressure) side. A quick tightening and it was fine. I did notice a small paint bubble on the deck directly above the turbo. There is about 2 inches clearance about the turbos but the deck was really hot to the touch. Question. I am looking for a product that can be applied (as a sheet or thin blanket) to the underside of the deck above the turbo. I have some chromed sheet metal shields that I may be able to fit to the turbos but would like the real protection of an insulator. Thanks in advance to the "collective", jerry knotts _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com><mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com><mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list DeTomaso@server.detomasolist.com<mailto:DeTomaso@server.detomasolist.com><mailto:DeTomaso@server.detomasolist.com> http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. PS - When you go to the JPL web page, pay attention to the Ceres bight spot. That is an image I did. We are trying to get one more IR Image pass over Occator before we depart for Adeona. "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [1]thimes@jpl.nasa.gov From: DeTomaso <[2]detomaso-bounces@server.detomasolist.com> on behalf of Terry Himes <[3]Terry.Himes@jpl.nasa.gov> Date: Thursday, June 30, 2016 8:51 AM To: Larry - Ohio Time <[4]Larry@ohiotimecorp.com>, 'Julian Kift' <[5]julian_kift@hotmail.com>, 'Paul Timko' <[6]thedrol@pobox.com>, "[7]detomaso@server.detomasolist.com" <[8]detomaso@server.detomasolist.com> Subject: Re: [DeTomaso] Insulation material? I will look into it. I have a piece of shielding in my office. It has 20 layers. But right now I am crushed building the departure sequences for Dawn. Plus we have Juno JOI this weekend. Crazy stuff happening all weekend. [9]http://www.jpl.nasa.gov/ Get back to you later... "A Purple Heart proves you were smart enough to hatch a plan, stupid enough to try it and lucky enough to survive!" Terry W. Himes JPL Jet Propulsion Laboratory Dawn Spacecraft Team Rosetta Sequence Team Lead Phone: (818) 393-6261 Cell: (818) 653-8213 Fax: (818) 393-3147 [10]thimes@jpl.nasa.gov<[11]mailto:thimes@jpl.nasa.gov> From: DeTomaso <[12]detomaso-bounces@server.detomasolist.com<[13]mailto:detomaso-bounc es@server.detomasolist.com>> on behalf of Larry - Ohio Time <[14]Larry@ohiotimecorp.com<[15]mailto:Larry@ohiotimecorp.com>> Date: Thursday, June 30, 2016 8:36 AM To: 'Julian Kift' <[16]julian_kift@hotmail.com<[17]mailto:julian_kift@hotmail.com>>, 'Paul Timko' <[18]thedrol@pobox.com<[19]mailto:thedrol@pobox.com>>, "[20]detomaso@server.detomasolist.com<[21]mailto:detomaso@server.detoma solist.com>" <[22]detomaso@server.detomasolist.com<[23]mailto:detomaso@server.detoma solist.com>> Subject: Re: [DeTomaso] Insulation material? I recall reading a blurb from NASA (ya I read that stuff too)that the gold color faced insulation was much better then the aluminum color faced insulation. You do see it in all the photos of the space craft. Let's see if Terry knows about this. Larry (what happened to the "Pure Gold" car?) - Cleveland -----Original Message----- From: DeTomaso [[24]mailto:detomaso-bounces@server.detomasolist.com] On Behalf Of Julian Kift Sent: Thursday, June 30, 2016 10:29 AM To: Paul Timko; [25]detomaso@server.detomasolist.com<[26]mailto:detomaso@server.detomas olist.com> Subject: Re: [DeTomaso] Insulation material? I second that the cloth and aluminium foils are top rate. Julian ________________________________ From: DeTomaso <[27]detomaso-bounces@server.detomasolist.com<[28]mailto:detomaso-bounc es@server.detomasolist.com>> on behalf of Paul Timko <[29]thedrol@pobox.com<[30]mailto:thedrol@pobox.com>> Sent: Thursday, June 30, 2016 7:05 AM To: [31]detomaso@server.detomasolist.com<[32]mailto:detomaso@server.detomas olist.com> Subject: Re: [DeTomaso] Insulation material? This is a list of stuff a lot or racers use to protect their bodywork. Some of it is pretty expensive, but so is paint... [33]https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER Paul #9270 On 6/30/2016 8:57 AM, Jerry Knotts wrote: 71 Pantera well worn 377 twin turbo motor. After a short trip yesterday I noticed one of my turbos was leaking oil. A small amount on the input (pressure) side. A quick tightening and it was fine. I did notice a small paint bubble on the deck directly above the turbo. There is about 2 inches clearance about the turbos but the deck was really hot to the touch. Question. I am looking for a product that can be applied (as a sheet or thin blanket) to the underside of the deck above the turbo. I have some chromed sheet metal shields that I may be able to fit to the turbos but would like the real protection of an insulator. Thanks in advance to the "collective", jerry knotts _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [34]DeTomaso@server.detomasolist.com<[35]mailto:DeTomaso@server.detomas olist.com> [36]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [37]DeTomaso@server.detomasolist.com<[38]mailto:DeTomaso@server.detomas olist.com> [39]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. _______________________________________________ Detomaso Email List is not managed by POCA Posted emails must not exceed 1.5 Megabytes DeTomaso mailing list [40]DeTomaso@server.detomasolist.com<[41]mailto:DeTomaso@server.detomas olist.com> [42]http://server.detomasolist.com/mailman/listinfo/detomaso To manage your subscription (change email address, unsubscribe, etc.) use the links above. Members who post to this list grant license to the list to forward any message posted here to all past, current, or future members of the list. They also grant the list owner permission to maintain an archive or approve the archiving of list messages. References 1. mailto:thimes@jpl.nasa.gov 2. mailto:detomaso-bounces@server.detomasolist.com 3. mailto:Terry.Himes@jpl.nasa.gov 4. mailto:Larry@ohiotimecorp.com 5. mailto:julian_kift@hotmail.com 6. mailto:thedrol@pobox.com 7. mailto:detomaso@server.detomasolist.com 8. mailto:detomaso@server.detomasolist.com 9. http://www.jpl.nasa.gov/ 10. mailto:thimes@jpl.nasa.gov 11. mailto:thimes@jpl.nasa.gov 12. mailto:detomaso-bounces@server.detomasolist.com 13. mailto:detomaso-bounces@server.detomasolist.com> 14. mailto:Larry@ohiotimecorp.com 15. mailto:Larry@ohiotimecorp.com> 16. mailto:julian_kift@hotmail.com 17. mailto:julian_kift@hotmail.com> 18. mailto:thedrol@pobox.com 19. mailto:thedrol@pobox.com> 20. mailto:detomaso@server.detomasolist.com 21. mailto:detomaso@server.detomasolist.com> 22. mailto:detomaso@server.detomasolist.com 23. mailto:detomaso@server.detomasolist.com> 24. mailto:detomaso-bounces@server.detomasolist.com 25. mailto:detomaso@server.detomasolist.com 26. mailto:detomaso@server.detomasolist.com 27. mailto:detomaso-bounces@server.detomasolist.com 28. mailto:detomaso-bounces@server.detomasolist.com> 29. mailto:thedrol@pobox.com 30. mailto:thedrol@pobox.com> 31. mailto:detomaso@server.detomasolist.com 32. mailto:detomaso@server.detomasolist.com 33. https://www.pegasusautoracing.com/group.asp?GroupID=HEATBARRIER 34. mailto:DeTomaso@server.detomasolist.com 35. mailto:DeTomaso@server.detomasolist.com 36. http://server.detomasolist.com/mailman/listinfo/detomaso 37. mailto:DeTomaso@server.detomasolist.com 38. mailto:DeTomaso@server.detomasolist.com 39. http://server.detomasolist.com/mailman/listinfo/detomaso 40. mailto:DeTomaso@server.detomasolist.com 41. mailto:DeTomaso@server.detomasolist.com 42. http://server.detomasolist.com/mailman/listinfo/detomaso
Larry, It's not jus good color, it's actual GOLD. A bit expensive unless you are operating with a NASA budget! Mike Sent from my iPhone On Jun 30, 2016, at 8:36, "Larry - Ohio Time" <Larry@ohiotimecorp.com> wrote:
Julian
Paul #9270
jerry knotts
Larry, You refer to 5923. http://www.provamo.com/Members/Registry/RegistryImages/RTHPNNA05923/RTHPNNA0... Chuck Thumbnail attached Larry (what happened to the "Pure Gold" car?) - Cleveland
participants (9)
Jack Donahue
JEFFREY COBB
Jerry Knotts
Larry - Ohio Time
Paul Timko
The DeTomaso Registry Guy
